49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> 3D Surface Pattern translation to AutoCAD
4 Posts No Rating |
For our Revit project I am saving 3D slices to AutoCAD for the MEP team to use with ABS. When I export the Reflected Ceiling plan I see the surface pattern of the 2x2 ACT grids but when I export a 3D view I get no surface pattern, no grid. One curious thing I noticed is that the plan view translation follows the export layer settings but the 3D translation seems to place 3D before the layer name. Ex. Instead of A-WALL the 3D translation is 3D-WALL. It makes me think there is a 3D translation table that I can’t seem to find that maybe doesn't have the surface pattern defined to a layer. anyone provide any insight?
4 Posts No Rating |
well I'm replying to my own post, can't be done. after working it out with Autodesk support the 3D solids in AutoCAD will not retain any of the information from Revit
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT |
Fri, Mar 28, 2014 at 2:30:00 PM
voronoi surface pattern |
Fri, Jun 24, 2011 at 2:14:03 PM
Surface pattern problem |
Tue, May 18, 2010 at 9:15:56 AM
Members: | 2030869 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
