58 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Radial array in families
Hi there, 2 issues for you.
Firstly i can't seem to use the radial array feature whilst creating a family. Very frustrating!
Secondly, invisible lines. Good feature, but is there a way to then display them later? I have a staircase where I have made some of the elements 'invisible' in plan view by using the invisible line command, but now I want to edit the staircase and want to delete my invisible lines. However, sounds obvious, but I can't see them to pick them!
Any tips?
Okay,
1. You can use the radial array in families in version 7.0 only. 6.1 does not have this feature.
2. I assume you have used the linework tool on the unwanted lines and changed them to invisible lines? If this is the case to restore the lines use the linework tool again and select <by category> this will effectively change the lines back to there original selves.
Excellent. Thanks very much.
Radial array in Families |
Tue, May 28, 2013 at 3:04:01 AM
Radial Array in a Family |
Mon, Apr 11, 2005 at 8:56:12 PM
Change start and end heights of elements in radial array |
Tue, Sep 20, 2016 at 7:06:49 AM
Parametric Radial Array |
Wed, Dec 14, 2011 at 1:39:23 AM
Radial Array in Elevation View |
Sat, May 29, 2010 at 9:20:46 PM
Members: | 2030512 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
