57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Fill pattern not showing up in print
Hi...I am having a problem that my fill pattern does not show up when i print my sheets at half scale. The exterior veiws are set up on the sheet as 1/8" scale and the stone fill pattern shows up on the screen but when i go to print at 50% on 11x17 it shows up as just blank. It prints in full scale. Is there some way to adjust this. We show all our prelims on 11x17 so this is crucial. the fill is the DRYSTACK LEDGESTONE model pattern. Any suggestions will be greatly appreciated...we're desperate!
10 Posts No Rating |
I had this problem too, took me a while to figure it out. Go to your Print Settings - Setup - Hidden Line Views. Change the setting to "Raster Processing" instead of "Vector Processing." HTH
Fill Pattern not show up when print |
Wed, Apr 25, 2012 at 4:08:55 AM
color scheme/fill pattern |
Mon, Jul 9, 2012 at 4:56:36 AM
Existing Walls with Coarse Fill Pattern Revit 2008 |
Wed, Aug 13, 2008 at 3:28:01 PM
Solid Fill Hatch |
Sun, Apr 1, 2007 at 8:56:31 PM
Model fill pattern not showing |
Wed, Jan 26, 2005 at 3:09:25 PM
Members: | 2022330 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
