29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Placing DWG files
Tue, Jan 16, 2007 at 4:04:33 PM | Placing DWG files
NewBe
I am placing an Autocad file with multiple drawings into Revit. Is there a way to crop out the different items on the sheets? OR do I need to break them out and import them as separate DWG's?
Thanks for any help.
Tue, Jan 16, 2007 at 4:47:11 PM | Placing DWG files
ArchWestCY
4.5 Stars: 7 Votes
If you import the .dwg into a drafting view, you can make callouts of each of the views you want.
Have you made a custom 'import lineweights.txt' file. This file should be setup so that Revit interprets your .ctb on import, and scales the lineweights of your .dwg accordingly.  If you have not, it is pretty easy, but a little time consuming.  Look under the File menu in the Import/Export Settings.  Then tell Revit what line weight each color represents.  Save this file, and you only have to do it once per .ctb.  It's a bit of a tangent, but worth considering.
 Good Luck
ArchWestCY
Wed, Jan 17, 2007 at 11:10:08 AM | Placing DWG files
NewBe
Thanks for the info. I did as you said and the callout created a new drafting page that references the newly created callout. However when I view the page there is nothing there.
Any ideas? What did I do wrong?
Thanks,Doug
Wed, Jan 17, 2007 at 11:56:43 AM | Placing DWG files
ArchWestCY
4.5 Stars: 7 Votes
Sorry.  It seems that I have given you a bit of bad advise.  I tried it, and could not get it to work.  I even looked at the visibility to make sure that imports were turned on, but they were and still didn't show up.  If someone else knows why, please let us know.
In the mean time, I have set up my .dwg layouts in such a way that I could drag the whole thing onto a sheet as one.  If you want these pieces on different sheets, then you will probably need to import them separately.
Sorry, again for leading you astray. I hope this different method works better for you.
ArchWestCY
Imported dwg files
Wed, May 10, 2017 at 10:25:29 PM
Linked DWG Files not visable in RCP
Mon, Oct 19, 2009 at 1:46:58 PM
DWG files for deck construction
Tue, Jan 16, 2018 at 8:49:05 AM
where to find CSV files or dwg terrain
Tue, Sep 8, 2009 at 1:41:14 AM
Exporting issues... exported dwg files missing information
Thu, Jan 24, 2008 at 11:43:21 AM
Page generation time: 0.5030
