107 Users Online (105 Members):
Forums >> Revit Structure >> Technical Support >> Turn off speciality equipment
4 Posts No Rating |
When linking a Revit Building model into Revit Structure, is their a way to turn off speciality equipment so that it is not visiable in the Revit Structure model? Rabbit
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Go to view you want to control. Then go to Visibility Graphics of that view [V V or VG keyboard shortcut] Then to 'Revit links' tab. Higlight linked file and click on 'Display Settings' which is by default on 'by host view' in RVT Link Display Settings change basics tab to 'custom' go to 'model categories' tab and choose 'custom' be sure to check the 'show categories from all disciplines' box and then turn off Specialty Equipment.
4 Posts No Rating |
Thanks for the information. I have already done all of what You just wrote. The problem is in Revit Structure I do not see Speciality Equipment to turn off. In fact I can turn off everything that is in the link revit and I still see only all of the speciality Equipment which is not what I want to see. It is kind of odd but I do not see Speciality Equipment until I switch from by host view to custom in the Visibility Graphic under the link Revit. This happened when I turned off the foundation in the link Revit and the Speciality Equipment then appeared. Rabbit
Combining Electrical Equip. & Specialty Equip. in a Schedule |
Tue, Apr 14, 2009 at 10:59:09 AM
massing |
Wed, Aug 22, 2007 at 4:38:47 AM
Schedules |
Tue, Sep 11, 2012 at 12:19:42 PM
Families' View Range |
Thu, Jan 21, 2010 at 9:13:04 AM
Equipment Schedules |
Tue, Jun 17, 2008 at 11:39:12 AM
Members: | 2017341 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
