Forums >> General Discussion >> Revit ROI >> Benefits of Revit Collaboration
We are giving a presenation and would like to include some information about the benefits of collaboration with other firms also using Revit. Could some one point me in a direction I might find some information on this subject? I have looked over the AutoDesk website but couldn't find any information like this. Thanks.
review the information posted by this blooger might give you some insight into what you are asking http://bimx.blogspot.com/
There is also some good information on this at the Autodesk Revit Structure website, white pages. Check it out. It goes through the entire process and benefits. The method is the same whether you are working with Revit Structure or Revit Systems.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
here is the link for the page Mr.Spot was referring to http://usa.autodesk.com/adsk/servlet/index?id=5523749&siteID=123112 HTH
Collaboration with worksets or link? |
Wed, Jul 8, 2009 at 11:10:58 PM
Collaboration For Revit |
Sun, Jul 19, 2015 at 7:31:46 AM
Single Disipline Revit Model Collaboration |
Thu, Jan 6, 2011 at 8:50:40 PM
Collaboration and dependent views |
Fri, Jun 9, 2017 at 10:14:44 AM
Architecture / Structure collaboration Melbourne |
Wed, Jun 19, 2013 at 10:52:39 PM
Members: | 2101741 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
