51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> filled region
Tue, Nov 23, 2004 at 6:49:43 PM | filled region
gY
I want to show a hatch pattern over neighbours site. Is it possible to turn off the boundary line of the region?
Tue, Nov 23, 2004 at 7:44:55 PM | RE: filled region
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sort of, rather than turning it off, you will actually have to use invisible lines as the bounday. Edit the filled region and select the boundary lines then change the type to <invisible>.
Tue, Nov 23, 2004 at 8:11:50 PM | RE: filled region
gY
Perfect! thanks
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:34 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:42 PM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:07 AM
FILLED REGION IN 3D VIEW OR PERSPECTIVE VIEW
Wed, Jan 26, 2011 at 5:10:06 PM
Visibility of Filled Region Boundaries over walls
Wed, May 24, 2017 at 1:55:00 PM
Page generation time: 0.9412
