66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Current Level
Thu, Jan 11, 2007 at 7:13:12 PM | Current Level
twebb
4 Stars: 1 Votes
I am trying to change the current level of my project.  It seems as though spot elevations, stacked walls etc are determining their heights based on my lowest level (Top of Footing - 99'-6"Winking instead of my First Floor (100'-0"Winking.  (I actually have a spot elevation and a level tag that are 6" apart that both say they are at 26'-0"Winking.  I tried to "Relocate This Project" but it didn't fix the discrepency.  One interesting thing I noticed was that when i change Level Type Properties from 'shared' to 'project', it says that the first floor is at 6".  (It had originally been drawn at 0'-0" then moved to 100'-0"Winking.  Seems as though when I added in the Top of Footing level everything got messed up.
 Any suggestion on how to fix this would be greatly appreciated.
Thanks.
Thu, Jan 11, 2007 at 7:26:02 PM | Current Level
twebb
4 Stars: 1 Votes
For some reason all of my close parentheses came out looking like weird smiley faces in the post above.  Please disregard, I can't stand emoticons.
Thu, Jan 11, 2007 at 8:55:14 PM | Current Level
TomDorner
4.5 Stars: 25 Votes
Check the properties of your spot elevations.  They can report either 'project' or 'shared' elevations.  Sounds like you have a mix of elevations being reported by each of them.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Fri, Jan 12, 2007 at 6:03:00 PM | Current Level
framerman
4 Stars: 13 Votes
It's so cute! jk jk. Must be because of the " and ) combined that does it. I think there's a check box in your personal settings to turn them off.
Edited on: Fri, Jan 12, 2007 at 6:03:34 PM
Changing display of walls below current level.
Wed, Jun 18, 2014 at 7:36:35 AM
Spot elevation and "current level"
Fri, Feb 17, 2017 at 3:11:01 AM
Level for current view only?
Tue, Oct 6, 2015 at 7:43:54 AM
View properties "cut plane" option greyed out?
Thu, Dec 11, 2008 at 6:57:03 PM
Cannot see walls above current level
Tue, Jul 4, 2017 at 9:04:20 AM
Page generation time: 0.5994
