33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> dwg 3D blocks
Wed, Dec 3, 2003 at 5:14:14 PM | dwg 3D blocks
Zimwanda
Is it possible to use ADT 2004 3D furniture blocks in Revit? If so, how?
Wed, Dec 3, 2003 at 6:37:53 PM | RE: dwg 3D blocks
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
You can import 3d dxf files. To do this go to file->import/link->dwg/dxf/dgn.. click the down arrow next to "files of type" and select "dxf" Find the file you want to import, select the options you want and click "open" that's it! hope that helps...
Hiroshi Jacobs
AutoCAD DWG Blocks
Sun, May 9, 2010 at 10:43:13 AM
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
Importing DWG with clipped blocks
Mon, Sep 17, 2012 at 12:00:44 PM
Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
Mon, Mar 21, 2011 at 3:03:58 PM
Some problems with the export from rvt to dwg
Thu, Jan 14, 2010 at 3:10:42 AM
Page generation time: 0.3591
