62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Filled Region schedule
Fri, Jan 5, 2007 at 3:38:59 PM | Filled Region schedule
twewer
Filled regions have an area value associated with them, how do I put that in a schedule?  I need to show different shaded areas on building elevations and then show the percentage of one from the other and filled regions are the only way I can think to do it.  Any suggestions?
Mon, Jan 8, 2007 at 10:36:17 AM | Filled Region schedule
rkitect
rkitect Avatar
4 Stars: 29 Votes
It appeasr as though Detail Items (the category that Filled Regions fall under) is not a schedulable category.  There may be a work around but I have not found it yet.  Let us know if you find anything.
Good luck!
Tue, Jun 17, 2008 at 10:06:33 AM | Filled Region schedule
psemrau
For Area analysis do not use filled regions, those are more like autocad's hatches.
Go to VIEW>NEW>AREA PLAN
There you can sketch areas just like filled regions. They behave more like Autocad's polylines, although a little better.  Areas created in area plans can be scheduled and calculated in formulas, just like you want to.  You can even create your own parameters and ratios out of calculations and use them in other formulas.  Other cool features is that you can show them very graphically with your color schemes (even in elevations in 2009)
 Also you can create various area plan schemes, like gross area/sellable area/interior area etc... those areas behave like rooms, but at another level that does not interfere with them.
Wed, Aug 5, 2009 at 7:27:12 AM | Filled Region schedule
Chymos
I completely agree with using area plans as mentioned above, but we already have a site plan that has many filled regions indicating different materials (grass, concrete, asphalt, etc.).  Was anyone ever able to determine a method to schedule the areas of filled regions and provide a total value?
Wed, Aug 5, 2009 at 7:51:58 AM | Filled Region schedule
Too bad you didn't split your surface and use materials to indicate your different areas.  You could have then scheduled those areas.  We split the topography to show grass/pavement/sidewalk and plat areas.
Wed, Aug 5, 2009 at 8:21:23 AM | Filled Region schedule
Chymos
Agreed!  But, now that it's done, is there a way I can use it as-is?  I.E. schedule filled region areas.
Wed, Aug 5, 2009 at 9:05:54 AM | Filled Region schedule
That was already answered at the beginning of this thread - no.
But you can edit each region, copy the sketch to clipboard, then use that sketch to split your topo face and then schedule those.   You don't have to do that....up to you - just would be my quick solution.
You could also create a dummy schedule - select your regions to list the area property and fill in your schedule manually.
Thu, Aug 6, 2009 at 12:26:29 AM | Filled Region schedule
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
yes but he said he wanted a elevation, is there a way to do a area plan "elevation"? if so let me know.
J. Allen Ball
Thu, Aug 6, 2009 at 6:22:01 AM | Filled Region schedule
Chymos
Seems as though if an element has a defined/measured property, it should be able to be scheduled.  Checking the property of a filled region clearly gives you an area calculation, so...
Mon, Jun 13, 2011 at 1:56:14 PM | Filled Region schedule
ShrutiHarve
Very late in this thread, but for those who are here seeking an answer:
IdeateBIMLink allows you to schedule areas of filled regions in Revit.
Ideate BIMLink lets you pull data from an Autodesk Revit file into user-friendly Microsoft Excel and push Excel data into Revit with equal ease. This indispensable tool works with Revit Extension Manager and gives you unprecedented access to Revit data – the I – in Building Information Modeling (BIM).
For more information about Ideate BIMLink and to download a trial copy, Please visit:
www.ideatebimlink.com
Best,
Shruti Harve, Application Specialist
Ideate,Inc
www.ideateinc.com
Mon, Jun 13, 2011 at 2:16:59 PM | Filled Region schedule
Shrut...  Your site is not clear about some important details.  I understand you can extract the data from Revit but how do you get it in a Revit schedule where Revit will not schedule the item?  RE - The original question.
Mon, Jun 13, 2011 at 3:13:19 PM | Filled Region schedule
ShrutiHarve
Ideate BIMLink even gives you access to data that Revit hides like Phasing, Design Options information, Detail Components etc. Since Filled Regions is categorized as a detail component you would need to use that as the schedule category, Here is the sequence of steps:
  • Launch Ideate BIMLink
  • Create New Link
  • Choose "Detail Components" as the category
  • Select the fields for the schedule in this case: "Area" and possibly "Filled Region: Name"
  • Hit OK and Export the data to Excel
Our website has a link to watch "Technical Overview" demo video, you can also watch additional videos on our youtube site:
http://www.youtube.com/user/IdeateInc#p/a
I hope that helps,
Regards,
Ideate,Inc
www.ideateinc.com
Mon, Jun 13, 2011 at 3:40:32 PM | Filled Region schedule
#13
That exports the data to excel but I asked how that comes back into Revit since Detail components can not be scheduled in Revit.
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
FILLED REGION IN 3D VIEW OR PERSPECTIVE VIEW
Wed, Jan 26, 2011 at 5:10:05 PM
Visibility of Filled Region Boundaries over walls
Wed, May 24, 2017 at 1:54:59 PM
Page generation time: 0.9791
