73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walls that will not Filter
Fri, Jan 5, 2007 at 1:01:24 PM | Walls that will not Filter
willsee
I am trying to filter out a wall type from a plan view.  I have created a filter for the specific wall that has about ten occurances in the plan.  I created a filter, loaded it into the VG of the plan view and toggled off the visiblility.  to my surprise only seven of the ten occurances became invisible.  There are three that remain visible.  I have tried creating additional filters for this wall type, but they remain.  I don't beleive there are any special edit profiles, or anything out of the ordinary associated with these three wall occurances.  They have a few wall hosted elements, but so did a few of the others that did filter out.  I'm totally at a loss.   Has anyone run into this, or have a work around?
Fri, Jan 5, 2007 at 2:18:35 PM | Walls that will not Filter
rkitect
rkitect Avatar
4 Stars: 29 Votes
How did you filter the walls?  There may be something in the filter properties that may have been overlooked.  Also, are you sure they are of the wall type that is being filtered?
If all else fails, turn the filter visibility back on, and use the match properties to make the three naughty walls match the other exactly, then turn the filter back on and see if that helps.
HTH.
Fri, Jan 5, 2007 at 4:02:40 PM | Walls that will not Filter
willsee
I created the filter by entering a word or abbreviation (like CMU) in the Type Comment feild for the Identity Data under the Type Porperties dialogue.  Then I created the filter by Type Comment equals to the same word or abbreviation.  This approach has worked countless times for simple filtering, until these three walls.
 To double check, I toggled on the visibility, matched the properities of the three walls to that of the walls that filtered originally and toggled the visibility to off again, and guess what.... they remained visible.  This is a stumper. Any other thoughts?
Mon, Jun 4, 2007 at 1:50:31 PM | Walls that will not Filter
pepsiqueen
pepsiqueen Avatar
anyone ever solve this? ive been trying all day and im about ready to chuck the pc out the window....
I'd rather be riding at whistler. or highland. thats good too.
Tue, Jun 12, 2007 at 1:41:12 PM | Walls that will not Filter
rkitect
rkitect Avatar
4 Stars: 29 Votes
Something b0rked.. see next post.
Edited on: Tue, Jun 12, 2007 at 1:53:04 PM
Tue, Jun 12, 2007 at 1:53:36 PM | Walls that will not Filter
rkitect
rkitect Avatar
4 Stars: 29 Votes
OK, here is what I did to succesfully filter walls:
Open your Visibility Graphics dialogue (type 'VG') and go to the Filters tab.
<img src="http://img509.imageshack.us/img509/6532/wallfilter1ew3.png">
Click Add then Edit/New to get to the Filters dialogue.  Here we will add your wall filter.
<img src="http://img513.imageshack.us/img513/7471/wallfilter2ay0.png">
Create a new filter, name it and then choose Walls from the categories list.  Under Filter Rule, I have choosen to filter by Type Name, you can choose whatever parameter you wish to filter by.  My Filter dialogue looks like this when finished with the filter rules:
<img src="http://img104.imageshack.us/img104/9113/wallfilter3cz0.png">
Click OK twice to get back to the Visibility Graphics dialogue.  Here you will add the filter.  Click Add, then select the Filter you just created.  Click OK to be back Visibility Graphics dialogue.  You should now be able to control the walls that are in that filter subset by clicking and unclicking the Visibillity Yes/No paramter.  Example:
I have 6 walls, alternating between a generic wall type and a wall type with 'CMU' in the type name.
<img src="http://img504.imageshack.us/img504/788/wallfilter4xm0.png">
Iturn the visibility for the filter off, et voila!
<img src="http://img504.imageshack.us/img504/4540/wallfilter5ng1.png">
I also like to make a yes/no instance parameter for walls called "Do not Show Wall" with a filter so I can turn individual walls off in different views.
Let me know if you have any problems or questions about this.
pS:  If the images do not show up, you will have to copy and paste the link to view them.  Sorry Sad
Seperating layers hatch with filter
Wed, Feb 12, 2014 at 3:15:31 AM
Structural walls in Architectural Model
Fri, Aug 6, 2010 at 9:51:38 AM
Filter walls by floor level or base constraint??
Sat, Jun 8, 2013 at 9:25:25 PM
selection filter
Sun, May 21, 2006 at 9:32:57 PM
Filter turns everything off
Wed, Apr 19, 2017 at 9:25:55 AM
Page generation time: 1.4232
