54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Dim. lines
I know you can change the dim. extention lines when you snap to the center of an object but can you change the outside extention lines as well to anything other than a solid line?
I do not see any options to change just the extension line type. However, if you really want to, there is a fake dimension family floating around out there that you could probably modify to do just that. It would probably be a pin to use that family for every dimension in your project. Besides, I think the dimensions look fine.
Diminsion under dim line |
Fri, May 18, 2007 at 10:10:30 AM
3d dim |
Mon, Jun 16, 2008 at 4:09:16 PM
Dimensioning Drafting Views |
Fri, Apr 3, 2009 at 9:03:24 AM
ref lines and dim extension lines |
Wed, Aug 20, 2008 at 7:27:34 AM
Settings for stringer |
Thu, Oct 3, 2013 at 7:53:55 AM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
