47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curtain Grid Question
Tue, Jan 2, 2007 at 11:34:00 AM | Curtain Grid Question
czeitz
Hi Folks,
Is it possible to create a curtain grid with more then one horizontal fixed spacing dimension?  For example, I have a curtain wall system that contains two different sizes of panel running horizontally - one large vision glass panel and one smaller metal panel (see attached image).
Any insight would be much appreciated...
Chaim
Tue, Jan 2, 2007 at 12:39:28 PM | Curtain Grid Question
TomDorner
4.5 Stars: 25 Votes
You cannot define an automatic curtain grid definition for multiple horizontal spacings.
You can however define an exterior curtain wall style with no automatic definition and then simply add your curtain grids as required.  You could also define the major horizontal spacing and add the required curtain grids manually.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Jan 2, 2007 at 12:50:57 PM | Curtain Grid Question
czeitz
thanks for the quick reply.  that's what I was afraid of...I guess I'll just drop in the other grid lines "manually."
Tue, Jan 2, 2007 at 2:08:51 PM | Curtain Grid Question
TomDorner
4.5 Stars: 25 Votes
A more advanced option is to create a new custom curtain panel that has the horizontal mullion you need for the secondary horizontal spacing built into the curtain panel definition.
This may not get you the two material types required though for the panels, but you coul play with it to see what is possible.
For some ideas see the Revit content on the Revit website.  See familes>curtain panels.
Tom
Tue, Jan 2, 2007 at 2:42:36 PM | Curtain Grid Question
czeitz
Thanks again...I was actually playing with that idea..."hanging" the second panel system off of the initial grid system.  I'll post my results if I can get it to work...
Chaim
Curtain Grid Problems [ 1 2 ]
Wed, Apr 10, 2013 at 5:57:45 AM
19
Curtain walls: Different spacings between mullions.
Tue, Jun 2, 2015 at 9:46:09 AM
curtain grid angle
Wed, Feb 11, 2009 at 4:27:26 PM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:47 PM
Curtain Grid Removing Segments
Mon, Jul 2, 2007 at 1:05:12 PM
Page generation time: 1.1803
