28 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> How to divide pipes into different categories
Thu, Dec 28, 2006 at 9:53:41 PM | How to divide pipes into different categories
kennethlau
 How to divide pipes into different categories, say Fire/Plumbing/Drainage/etc and that the pipes could be display in different color under each categories?
Wed, Jan 3, 2007 at 4:16:03 PM | How to divide pipes into different categories
rkitect
rkitect Avatar
4 Stars: 29 Votes
Are you ready for this reply?  It can get complicated.
You can either make a different pipe family for each category, or set up one pipe family with many different parameter settings to separate the pipe types.
In option one, you could essentially copy the pipe family file and just rename it.  But then you have many different pipe families to choose from and the operator could accidentally choose the wrong pipe when placing it in the family.  You can set up a new object style in the family  that will allow you to control colors within the project.
Option two is a scripting mess waiting to happen but can be done with some knowledge on parametric formulas and a lot of patience.  The advantage, obviously having everything contained in one file.  The disadvantage is that there would be a lot of filtering and object style setup required in the project to do this.  If you will be doing this a lot, you can build the filters and object styles into the default template you use for new projects and this would save you tons of time.
Well, I think I got you started.  There is a chance I only confused you though.  So let me know if you need any further assistance.  Good luck!
Thu, Oct 18, 2007 at 5:52:34 PM | How to divide pipes into different categories
RRamey
rkitect
Wher would one fine the pipe family file to copy and modifiy?
 RRamey
Duo pipes - Twin pipes for central heating
Wed, Jan 16, 2019 at 3:48:53 PM
REVIT MEP 2012 Demo Phasing Disconnecting Pipes
Wed, Jul 18, 2012 at 12:20:02 PM
divide a line
Wed, Sep 20, 2006 at 3:30:52 AM
how to divide a line or object in equal parts?
Tue, May 14, 2019 at 5:50:58 AM
12
Collapsing Browser Categories & Sub Categories
Wed, Mar 4, 2009 at 9:29:51 AM
Page generation time: 0.2189
