75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Site Topographics
Thu, Dec 28, 2006 at 3:22:03 PM | Site Topographics
ddhobbs
I am a new user to REvit City but have been working with Revit systems for a while now.
Our firm is currently working with Revit Series Building 9.1. In previous versions I was able to import Autocad contours lines and surevy elevation points to create a topo surface. I seem to be haveing difficulty repeating this task. Not sure if I have missed something or if Revit 9.1 has some bugs with the site tabs. Can anyone help.
THanks
Darrell
Thu, Dec 28, 2006 at 3:45:37 PM | Site Topographics
TomDorner
4.5 Stars: 25 Votes
I had the same problem yesterday with Revit 9.1.  Try downloading the latest build just posted today to see if it clears up the problem. [I haven't had time to try yet]
Tom
www.reviteer.com   http://twitter.com/Reviteer
Sat, Dec 30, 2006 at 12:41:54 AM | Site Topographics
mibzim
You now have to import the dwg as 3D (ie all views) to perform this function - not sure if it is designed this way or revit has managed to go backwards? Have a go and see if that works
Sun, Dec 31, 2006 at 11:13:53 PM | Site Topographics
ddhobbs
I have found that when importing the the 3d points from autocad files, revit tutorials indicate that the (in this view only), do not check the view only option, points will be imported to generate the topo surface.. This seems to take care of the issue I was having. Thanks for your comments, thanks for the replys. I hope to use the revit City site more often as I have come across several useful tips.
Darrell
Mon, Jan 1, 2007 at 4:21:58 PM | Site Topographics
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
FYI, you've always needed to import an autocad contours file in 3D (current view only - not selected) in order to make use of the 3D information in order to generate a topography...  There has been no change in 9.1
Regards,
Chris.
Mon, Jan 1, 2007 at 6:59:21 PM | Site Topographics
mibzim
there you go - ask the Master! Cheers Chris!
Hidden Objects in Sheet views
Thu, Jun 12, 2008 at 4:38:08 PM
Problem with Reigion Hatching on Site Plan [ 1 2 ]
Tue, Feb 25, 2014 at 4:19:16 PM
26
Creating a Site
Sat, Apr 10, 2010 at 6:19:22 PM
14
Advice on creating a site plan
Mon, Jul 12, 2010 at 5:04:04 PM
New Revit Site
Thu, Jul 5, 2007 at 10:31:06 AM
Page generation time: 0.5422
