73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ceiling Elevation on finish schedule
Thu, Dec 28, 2006 at 9:12:17 AM | Ceiling Elevation on finish schedule
thedufster
I am trying to get the Ceiling elevation to show up on a finish schedule. I cannot seem to get a multi catagory to show up the ceiling offset value so I can put in on a finish schedule.
Sat, Dec 30, 2006 at 1:23:28 AM | Ceiling Elevation on finish schedule
mibzim
From what i can remember, multi-category schedules only schedule parameters that are common to all elements. I think that ceiling heights are a parameter unique to ceilings, and you probably wont get that to show up in a multi-category schedule - i stand to be corrected tho...
Sun, Dec 31, 2006 at 9:28:23 AM | Ceiling Elevation on finish schedule
robinballew
robinballew Avatar
3 Stars: 4 Votes
Under room schedule you can show unbounded height or upper limit. Both will give you a room ceiling height that reflects the room and can be changed per room.
BallewDesigns.com
Thu, Jan 4, 2007 at 12:59:11 PM | Ceiling Elevation on finish schedule
thedufster
I got simple  I set to calcuate the volumn with the upper limit set above ceiling the divided by the area in a calculated value get the height every time.
Thanks
Ceiling Types in Finish Schedule
Mon, Nov 19, 2012 at 9:39:25 AM
Finish Schedule
Mon, Aug 10, 2009 at 6:25:51 AM
Getting Ceiling Tags to read on a Room Finish Schedule
Tue, Feb 28, 2012 at 12:32:29 PM
Ceiling Height, Formula Field in Schedule???Possible or not???
Tue, Nov 3, 2009 at 10:27:52 AM
Ceiling Heights in schedule????
Wed, Aug 20, 2008 at 2:45:49 PM
Page generation time: 0.6067
