81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> stadium style seating
Wed, Dec 27, 2006 at 4:59:01 PM | stadium style seating
yoiyoi
i am trying to create a sloped floor with stadium style seating ie stepped-seating. i 've tried using the stairs modelling command and changing the parameters of the tread to match the size for each level of seating . alternatively, i am considering having multiple floors of varing elevations and joining them with vertical mass elements.
what is the best way to go about achieving this most efficiently. out of my wits. any help will be appreciated
Wed, Dec 27, 2006 at 6:00:49 PM | stadium style seating
thebigbrowncat
thebigbrowncat Avatar
3 Stars: 1 Votes
CHECK this file attachment. What I did was I created a slab of floor on my floor plan view (you have an option of placing a chair component - in this sample I used a classroom type armchair...have no time to look for an appropriate chair). Then from the floor plan view again just copy that slab of floor to the number of steps you needed. then select one floor at a time changing their HEIGHT OFFSET FROM LEVEL from the Elements Properties to create different leveled floors (stepped floors). Just check the file.
Wed, Dec 27, 2006 at 6:34:21 PM | stadium style seating
framerman
4 Stars: 13 Votes
check this thread out on augi. it might be what you are looking for
http://forums.augi.com/showthread.php?t=52217
Thu, Dec 28, 2006 at 12:18:30 AM | stadium style seating
thebigbrowncat
3 Stars: 1 Votes
hi framerman,
The sample in the augi thread is only good for 2D. I don't know if it will work well with a 3D component such as a chair.
Thu, Dec 28, 2006 at 12:20:16 AM | stadium style seating
thebigbrowncat
3 Stars: 1 Votes
I downloaded the file and tried viewing it in 3D but the chairs are flat.
Thu, Dec 28, 2006 at 9:47:51 AM | stadium style seating
TomDorner
4.5 Stars: 25 Votes
In Revit 9.0/9.1 you now have the option of making families workplane based.  I modified a stadium seating family and then created a stepped slab as a sweep to place the seating on.  See the attached snippet of the project for further ideas.
Tom
Thu, Dec 28, 2006 at 11:59:39 AM | stadium style seating
thebigbrowncat
3 Stars: 1 Votes
Oh yeah i remember my colleague mentioning that. Hey tom, your solution is better! nice one!
Wed, May 2, 2007 at 4:23:21 PM | stadium style seating
Tmifsud
Thanks Tom for sharing.  Just thought I'd add a tip for others who may find this thread.  To change a family to workplane based...while editing family go to Settings Menu and choose "Family Category and Parameters".  Then choose check box for workplane based.  See attached image.  After reloading the family you'll then be able to use rehost function to select the desired plane.
Thu, Apr 30, 2009 at 9:36:58 AM | stadium style seating
Mufu
hey guys i am a complete noob with this i have to design two theatres and i am completely stuck with this i have got a footprint plan from autocad which i am using to come up with the theatre but would really liek a step by step video or tutorial on hwo to create these steps and the ramp on the side it would be of great help thanks
muf
V. 2018 - cutting wall sweeps with void forms for stadium seating
Thu, Jan 11, 2018 at 12:50:20 PM
Seating bowl problem
Mon, Jun 11, 2012 at 2:13:46 PM
auditorium seating
Wed, Mar 7, 2007 at 8:43:03 AM
stadium
Fri, Jun 13, 2014 at 1:28:21 PM
Dome Roof for Stadium
Fri, Dec 5, 2008 at 11:47:55 AM
Page generation time: 1.3663
