44 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> how can i recover a lost file?
i recovered a lost file from my computer with pc inspector file recovery, but when i try to open it i get the following message: data in file (*.rvt) needs to be manually upgraded, please contact your autodesk revit service provider.
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
If you receive this error message your only real solution is to do as it says and send the file away for manual upgrading if you don't have another backup somewhere that can be opened... If you did have the original file before it became corrupted, and it did so in a single session you could possibly recreate it using a journal file. But I'm unsure of your exact circumstances so I'm not sure whether this would be relevant to you. HTH.
Regards,
Chris.
Revit 2012 - Try to recover rvt file from Journal Files |
Mon, Jun 25, 2012 at 12:16:27 PM
recovering lost files |
Tue, Sep 2, 2014 at 1:28:11 PM
recover unsaved files |
Mon, Jul 12, 2010 at 9:52:58 AM
"too many missing elements, cannot open file" after upgrading to revit 2017.1.1 |
Tue, Apr 4, 2017 at 9:10:56 AM
ARGHHHHH....lost file. Found journal txt file though |
Mon, May 5, 2008 at 7:07:46 PM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
