Forums >> Revit Building >> Technical Support >> import ADT details
1 Posts No Rating |
I'm have imported ADT details into our drawing set, and occasionally the defpoints layer appears or the files will be in color.
I have tried the following and nothing seems to work consistently
1. I have gone in to the visibility/graphic overrides to turn off the defpoint layer.
2. Reload files, but they come in as color or the defpoints box reappears.
Any help would be great, thanks.
3 Posts No Rating |
hi,
do you really need the defpoints layer at the revit project?
what happens if you erase it in the objectstyles -> imported objects -> categorie?
you can also try to rease the layer at adt and import the dwg then in revit.
greetz
titania
Post edited on 2004-11-17 04:33:28
20 Posts No Rating |
I have a set of ADT files that I need to upload/link/import to Revit. I've tried importing it as a DWG and DXF but Revit doesn't seem to like it. HELP!!! Do i have to treat the import file.
Hi, export your ADT files in IFC and import in Revit in IFC also....
i only have Cad in my computer, the files are opening in 3d Cad and from there i can't export as a IFC file. Any other suggestion to export form cad.
Converting 3D objects from ADT to Revit families? Any suggestions? |
Wed, Nov 22, 2006 at 11:35:49 AM
Bringing ADT lines into a Revit Model |
Wed, Mar 4, 2009 at 6:56:23 AM
import cad details |
Sat, Nov 22, 2008 at 11:52:15 AM
REVIT X ADT |
Sun, Jan 8, 2006 at 10:40:43 PM
Importing .dwg details |
Wed, Jul 12, 2006 at 12:23:48 PM
Members: | 2101656 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
