Forums >> Revit Building >> Technical Support >> Filled Regions - How to hide the boundary line?
5 Posts No Rating |
In dressing up final documentation, I find it useful to use Filled Regions with solid white fill to mask content I don't want to show but which is not effectively controlled by Visibility settings. This works fine except for the aggevating side effect that I can't find a way to make invisible the line boundaries of the Filled Region. Any workarounds out there? Thanks. Barney
take a look at this thread http://www.revitcity.com/forums.php?action=viewthread&thread_id=4613 HTH
5 Posts No Rating |
Thanks, coreed. That answers my problem - should have searched first. Next Q: While above works when you first create the region, there doesn't seem to be any way to change the boundary line type after the region is already there - this is not a property of the region object. Is this a correct read? Thanks. Barney
1 Posts No Rating |
if you select the filed region, the click edit (on the options bar) you can change the line type from the list.
i think ants answered that question. but, one thing you should always do after posting a question is go back and view it, then look at the bottom of the page under similar threads. i think this is the greatest new feature of the website. It would be nice if there was a away to type in questions and bring up similar threads without having to post. HTH
Edited on: Sun, Dec 17, 2006 at 7:10:24 PM
Tracing filled regions with linework |
Tue, Mar 3, 2009 at 10:24:53 AM
Chaning the ouline line style for filled regions |
Thu, Jul 19, 2007 at 6:31:49 PM
filled regions... |
Sat, Jun 13, 2009 at 4:48:39 PM
Masking Regions and Filled Regions - Which Is In Front? |
Fri, Oct 28, 2011 at 2:26:56 PM
Masking Regions and Filled Regions BEHIND 3D Objects |
Wed, Aug 1, 2012 at 8:10:28 AM
Members: | 2102330 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
