99 Users Online (98 Members):
Forums >> Revit Building >> Technical Support >> autocad hatch problems
31 Posts No Rating |
I have exported my revit elevation to autocad 2004. when i open the file, and try to perform a hatch edit I get the message "error in reading the hatch pattern", and am not able to edit or clone its properties. anyone out there know a workaround to get all the .pat files from revit to work in autocad? cc
----------------------------------- Callum Crawf
DCA Architecture
906.938 Howe st
Vancouver BC, Canada
604.688.8370
www.dc-arch.ca
callum@massivescale.com |
![4 Stars: 13 Votes](/images/stars_4.gif) |
I guess I'm not getting the "why" you are wanting to edit hatches in AutoCAD. I'm not sure, but the hatch patterns in Revit are model based and drafting based and this may be where you are running into problems. Toggle between the two and see if that works. If not you can edit your hatches in Revit first before exporting and that should work for you I would think.
Export to Autocad 2005 (Hatch Patterns Go Missing) |
Mon, Feb 14, 2005 at 6:13:58 AM
Hatch Patterns |
Thu, Sep 14, 2006 at 10:05:02 AM
Custom Hatch Patterns |
Thu, Dec 23, 2004 at 3:00:32 PM
Importing Gray to Revit |
Fri, May 11, 2012 at 2:47:26 PM
How to set the origin for hatch in revit |
Fri, Sep 16, 2016 at 3:03:45 PM
Members: | 2017356 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
