115 Users Online (113 Members):
Forums >> Revit Building >> Technical Support >> Wall Panel Location
26 Posts No Rating |
I have a user with a metal building that will have a brick base, watertable brick, and a metal wall panel above. How do you move the wall panel so that it is aligned with the back face of the brick. I can move the back face of the panel, but Revit doesn't allow me to move the front face of the panel. The panel was made from assigning a layer to a split region. I've attached the file for review. Any thoughts?
Do it as a stacked wall instead of a compound wall.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Do you mean actually place another wall on top of the 1st one - two different wall styles?
'Stacked Walls' in Revit are a special wall type that nests other 'regular' wall types in a vertical stack. You can control the height of each wall type nested in and control the alignment of each of the wall types relative to each other. Check the Revit help file for more information.
Got it. Everything is aligning fine now. Thanks for the help!
Custom Precast Wall Panel |
Wed, May 20, 2015 at 3:10:54 PM
Tilt Panel Curtain Wall - On the right track? |
Sat, Nov 10, 2012 at 7:17:55 PM
Making Last Panel in Curtain Wall Cropped Instead of Squeezed |
Thu, Feb 11, 2016 at 10:57:21 AM
Precast Panel / Dado panel - Wall Schedule to issue drawings for shop detailing. |
Tue, Sep 30, 2014 at 7:03:41 AM
curtain wall panel losses end - edge |
Tue, Jul 15, 2014 at 7:04:22 PM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
