45 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Titleblocks
Tue, Dec 12, 2006 at 9:58:01 AM | Titleblocks
mcoffey
The company I work for has 7 different offices, thus we have 7 different addresses. I'd like to create one titleblock family with 7 different components each with a different address. So, when I load the titleblock family I can pick from the type selecter the proper titleblock for the office I want. Similar to how a dynamic block works in ACAD. Is there a way to do this or do I have to create a seperate titleblock family for each office?
Thanks,
Matt
Tue, Dec 12, 2006 at 11:04:37 AM | Titleblocks
TomDorner
4.5 Stars: 25 Votes
You can make use of a 'type catelog' in Revit that holds all the office and address information.  When the user loads the titleblock family they are presented with a type selection grid.  Load a steel column to see a type catalog in action.  You need to create generic annotations that you load into your titleblock and then link to the parameters fed from the type catalog.  It gets a bit tricky and is not something most newbies can get a handle on.
Check the Revit help file for some guidance on type catalogs.
You could also use simple visability parameters to control the text display of each office and make a new 'type' based on the visibility selections.
HTH get you going
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Dec 12, 2006 at 12:27:07 PM | Titleblocks
mcoffey
Thanks for the suggestion. I think a visability setting is exactly what I want. How would I go about creating one or actually 7 of those in one titleblock?
Tue, Dec 12, 2006 at 1:25:38 PM | Titleblocks
TomDorner
4.5 Stars: 25 Votes
Take a look at this example for some ideas on how to accomplish with visibility parameters.
Tom
Tue, Dec 12, 2006 at 1:37:39 PM | Titleblocks
mcoffey
I see now. Thank you Tom. That's a big help.
TitleBlocks
Fri, Dec 8, 2006 at 8:08:02 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:33 PM
Labels in Titleblocks?
Mon, Nov 10, 2008 at 3:30:01 PM
Titleblocks
Mon, Mar 17, 2008 at 3:03:10 PM
Multiline text on Titleblocks
Sun, Oct 5, 2008 at 8:17:13 PM
Page generation time: 10.0164
