79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Filled region showing up in an underlay
Fri, Dec 8, 2006 at 3:33:11 PM | Filled region showing up in an underlay
Kartyh
Is in possible to have a filled region show up in a underlay. The filled region is a drated element and I can not get it to show up in my underlay. Any suggestions?
Fri, Dec 8, 2006 at 3:44:30 PM | Filled region showing up in an underlay
laurabh
Drafted elements are view specific.  Would it work to just copy and paste aligned?  If not, what exactly are you trying to do?
Fri, Dec 8, 2006 at 4:07:51 PM | Filled region showing up in an underlay
Kartyh
I am trying to find a backwoods soluton, because else nothing seems to work, to being able to tag an item above with an actual smart tag in which I do not see the actual item in the plotted view.
My dilema is that I want to tag a wall above that I do not want to visually show in my lower view (it is a stacked situation). I was attempting to use an overlay to show the wall above in my referenced view then draw a filled region in the underlay view to cover the wall so that it does not show up in the plotted view.
 Another solution: is it possible to move a filled region under a model item in a view. example under a wall?
Fri, Dec 8, 2006 at 4:16:12 PM | Filled region showing up in an underlay
laurabh
Drafted elements (including filled regions) always show up on top of model elements.  This is this case in any view, so your suggested solution won't work.  Sorry, I don't have any ideas myself.
(On a side note, if you're posting about a question you've asked before in this forum that explains the situation, I'd keep posting in that thread so that people know the background of the question.)
Fri, Dec 8, 2006 at 5:11:22 PM | Filled region showing up in an underlay
normanoid
I posted a work around solution here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=6002
Filled region within detail family not showing in design option
Sun, Sep 21, 2014 at 7:24:46 PM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Problem with filled region
Mon, Apr 4, 2016 at 11:26:17 AM
Some Filled Region patterns showing solid
Tue, Oct 13, 2015 at 4:04:46 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
Page generation time: 0.6316
