149 Users Online (147 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Plotting Scale Issues
Fri, Dec 8, 2006 at 10:01:48 AM | Plotting Scale Issues
MongooseST7
MongooseST7 Avatar
I have assemble a series of drawings at 1"=20' with a define sheet at 11x17 for my printer. When I print out the 11x17 the scale is wrong. It appears that the sheet edge as define is being printed out on the actual paper size with a defined border, in other words the edge of the define revit sheet at 11x17 is inset on the actual 11x17 paper......any ideas or guidance
Thanks
Fri, Dec 8, 2006 at 12:34:25 PM | Plotting Scale Issues
ArchWestCY
4.5 Stars: 7 Votes
Have you checked the print scale on the setup dialog of the print window?  It should work if you have it set to 100%.  if it is 'Fit to Page' then Revit will try to print that border.
I'm not sure if that is the problem, but it might be a good place to start looking.
ArchWestCY
Plotting
Tue, Jun 23, 2009 at 5:51:34 PM
plotting / printing
Wed, Feb 13, 2008 at 8:31:13 AM
Scale issues
Tue, Feb 18, 2014 at 10:34:47 AM
PAT file scale issues
Thu, Mar 20, 2008 at 7:03:29 AM
Plotting
Mon, Oct 20, 2008 at 10:23:03 AM
Page generation time: 0.5410
