Forums >> Revit Building >> Tips & Tricks >> batch rendering queue..
Fri, Dec 8, 2006 at 4:41:21 AM | batch rendering queue..
marconazzi
do U know if there is a way to make a rendering queue? i mean, a batch file thar render a lot o scenes, so it can runs in one night?
thanks
Fri, Dec 8, 2006 at 3:05:50 PM | batch rendering queue..
dduarte
dduarte Avatar
3 Stars: 2 Votes
Construct a walkthrough and just render the key frames.
David
Fri, Dec 8, 2006 at 3:39:49 PM | batch rendering queue..
ArchWestCY
4.5 Stars: 7 Votes
That seems like a really good idea.  I'll have to try that.
ArchWestCY
Fri, Dec 8, 2006 at 3:42:31 PM | batch rendering queue..
TomDorner
4.5 Stars: 25 Votes
Another option to consider is rendering each scene on multiple computers if you have spare PC's available.  A little known secret is that you can install Revit on any PC in 'demo' mode which allows you to render and export the rendered image as long as you don't make ANY changes to the Revit model or scene settings.
If you use this approach, you need to make sure that all the MLIB's are in a central place and that all Revit installations have a path the the MLIB's.
I did this all the time where I used to work.  Just make sure that you beat everyone to work or leave them a note not to close out Revit when they arrive in the morning.
Tom
www.reviteer.com   http://twitter.com/Reviteer
BATCH RENDERING
Wed, Mar 18, 2009 at 2:02:20 PM
Revit Family Batch Updater - Anything like this?
Wed, May 12, 2010 at 6:03:46 PM
Batch printing sheets from multiple files
Wed, Feb 17, 2010 at 2:45:00 PM
REVIT 2012 BATCH CONVERTER
Thu, Jun 30, 2011 at 4:27:10 PM
Multiple renders or Batch rendering
Fri, Jun 6, 2008 at 1:20:49 PM
Page generation time: 1.8587
