117 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Interior Elevation disappearing lines
Thu, Dec 7, 2006 at 1:34:08 PM | Interior Elevation disappearing lines
derxaj
3.5 Stars: 3 Votes
Has anyone ever had the problem when printing interior elevations, certain wall and floor lines wont print.  They are visible on the screen but when printed they disappear.  I do not think it is a driver issue because it happens on every printer we have, including the PDF writer.
Anyone else ever have this problem?  Please help!
Thanks
Adam
Thu, Dec 7, 2006 at 2:37:16 PM | Interior Elevation disappearing lines
Leslie
this is an old issue and has to do with how your crop line sits on top of your view.
In our office we pull the crop lines slightly outward and draft wide lines over our elevation edges.
Would be nice if the crop box could be redifined with wide lines, wish item for a long time.
Thu, Aug 30, 2007 at 1:57:30 PM | Interior Elevation disappearing lines
twhisker
2.5 Stars: 5 Votes
I just posted the same question and I just got my answer with a little fiddling and a hint from a friend.
 Select the boundary box.  right click and select Override Graphics In View (by category) change the line weight to a higher value.
BAMM - your boundary box is now a fat line for interior elevations!!
 Anyone know how to make this change permanent to either all projects as a system setting or at least to Interior elevation views?
Revit Architecture 2010
Thu, Aug 30, 2007 at 4:53:38 PM | Interior Elevation disappearing lines
The crop boundry line over-ride is only available in Architecture - wasn't in 9.1.
Our problem is that we leave all of our crop boundries on and then in mass prints, we use the checkbox to  not print crop boundries.  Looks like we may change that process now.
disappearing elevation "arrow"
Fri, May 2, 2008 at 8:31:03 AM
CAD import disappears in interior elevation
Fri, Dec 6, 2019 at 12:40:47 PM
Interior Elevation Tags
Wed, Oct 9, 2013 at 2:23:37 PM
Lines disappearing in elevation/section view.
Thu, May 16, 2013 at 7:31:33 AM
Revit 2011 Multiple Interior Elevation References
Wed, Oct 26, 2011 at 9:01:49 AM
Page generation time: 0.6859
