Forums >> Revit Building >> Technical Support >> default export to DWG settings
51 Posts No Rating |
A user in my office says that at one point in time his export to DWG settings were changed so that the default DWG version was set to 2000 instead of 2004. Is this possible? I didn't see anything in the help file nor when I searched these forums.
at one time it may have, but Autodesk no longer supports Autocad 2000 HTH
Yes, I am aware that they no longer support 2000, but it is still an option in the file type pulldown menu when one is exporting to a DWG. We have a consultant on a very old job in our office that is still working on 2000 and this user in my office would like for the default to be as a 2000 file instead of 2004.
1 Posts No Rating |
Did you find out how to do this? if so can you post
3 Posts No Rating |
I had the same question and came to this thread with no answer. I'll post what I found in case anyone else wants to know how to change the defaul setting.
Go to export a DWG like you normally would. In the first pop-up screen in the "Select Export Setup" box, select "...". Select the last tab "General" and at the bottom there should be a drop down box with all the different CAD formats.
Hope this helps.
default DWG export acad plotting |
Fri, Jun 20, 2014 at 7:25:00 PM
Exporting Revit 2009 (.rvt) to AutoCAD (.dwg) |
Mon, Jul 13, 2009 at 3:55:28 PM
Export 3d DWG issues |
Fri, Jun 28, 2013 at 8:27:03 AM
Export Linework colors to DWG |
Wed, Sep 14, 2016 at 12:04:13 AM
default settings - can they be printed out? |
Fri, Dec 1, 2006 at 11:40:12 AM
Members: | 2099093 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
