36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 3ds Max -->Revit Converter????
Tue, Dec 5, 2006 at 9:50:27 PM | 3ds Max -->Revit Converter????
tavishhill2003
Does anyone know of any possible way to convert a 3ds max 3d model into a file that can be dropped into Revit?  Thanks!
-tav
Wed, Dec 6, 2006 at 4:27:07 AM | 3ds Max -->Revit Converter????
coreed
coreed Avatar
4 Stars: 16 Votes
i think you will have to covert the 3ds to dwg or 3ds to dxf and then to dwg
but you will have import/link the file in or create mass and them import/link the file in
i don't think you will be able to drag and drop the file into revit.
also check out this link
http://www.revitcity.com/tutorials/how_to_grow_your_family/
HTH
Edited on: Wed, Dec 6, 2006 at 9:34:08 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Dec 6, 2006 at 8:17:54 AM | 3ds Max -->Revit Converter????
framerman
4 Stars: 13 Votes
just a warning when you do, if your model has a high poly count, you might notice some considerable slowdown. you should try multires on your model before exporting it to reduce the polys to something you can live with.
this is one thing revit needs to improve on greatly is viewing of models with higher poly counts
Wed, Oct 22, 2008 at 11:12:35 PM | 3ds Max -->Revit Converter????
lillian
has anyone successfully accomplished this?  I'd love to get some details!  Thanks!
Thu, Oct 23, 2008 at 12:02:38 PM | 3ds Max -->Revit Converter????
4 Stars: 203 Votes
Hi, check above the awnser from "Coreed"...
Revit bring into 3ds Max [ 1 2 ]
Sat, Dec 25, 2010 at 6:24:34 PM
17
Intermediate Revit user here looking for advice on 3ds max [ 1 2 ]
Thu, Sep 8, 2011 at 3:41:36 PM
18
Best Reference to Rendering Revit Models in 3DS Max
Mon, Oct 31, 2011 at 11:00:39 AM
Revit to 3DS Max and creating FBX files
Fri, Apr 26, 2024 at 4:30:42 AM
Revit Walkthrough Path/Camera to 3Ds Max
Fri, Aug 7, 2009 at 11:37:27 AM
Page generation time: 3.1723
