69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Converting a Revit v 8.0 file into Archicad v10.0
Tue, Dec 5, 2006 at 9:31:46 PM | Converting a Revit v 8.0 file into Archicad v10.0
whoopsyvroom
Is it possible to convert a Revit file into an Archicad file. We are trying to produce a marketing perspective through an architectural firm that only uses Archicad.
Tue, Dec 5, 2006 at 9:40:32 PM | Converting a Revit v 8.0 file into Archicad v10.0
Thread Post Kudo! #2
eldados
eldados Avatar
4.5 Stars: 8 Votes
from revit to Archicad? No Possiblo Sad you can try and export to dwg and import that into Archicad, but you will loose all parametric information... too much work, better off starting from scratch in Archi
Integrator
KarelCAD
Tue, Dec 5, 2006 at 9:52:30 PM | Converting a Revit v 8.0 file into Archicad v10.0
whoopsyvroom
Thanks Eldados. I had a feeling that was going to be the response. If you don't ask you will be left wondering.
Wed, Dec 6, 2006 at 6:28:46 PM | Converting a Revit v 8.0 file into Archicad v10.0
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Both products support IFC so you could try it that way...
I haven't used the latest version of IFC so not sure as to how complete the transfer is.
Regards,
Chris.
Thu, Dec 7, 2006 at 5:51:49 PM | Converting a Revit v 8.0 file into Archicad v10.0
whoopsyvroom
Thanks Mr Spot. We tried the .ifc conversion but without success. All we got was a blank file when we tried to convert the .ifc drawing into the Archicad format. We have now nearly completed an Archicad drawing suitable for our needs. Thanks everyone for the suggestions.
Tue, Feb 27, 2007 at 11:48:14 AM | Converting a Revit v 8.0 file into Archicad v10.0
mjpatrickid
1 Stars: 1 Votes
Yeah, this was a bummer for us ArchiCAD users.... same with the ability to bring in a Cyclone cloud.  (Although I dont know if Revit can bring in the cloud, but AutoCAD can)
I wish I could export a Revit family into ArchiCAD...
Mon, Mar 23, 2009 at 4:42:35 PM | Converting a Revit v 8.0 file into Archicad v10.0
BVHdarin
I am currently working with a design team whose responsible for producing drawings through schematic design and then handing it off to my architecture team.  They use ArchiCAD and we are on Revit, will their object creation with attributes translate to information that can be use in Revit....ie door information in their model, will it be useful in our model?  How well does an ArchiCAD file that is transfered into an IFC file translate to useful information in the Revit model?  Thanks in advance to your response.
Tue, Mar 24, 2009 at 10:17:38 AM | Converting a Revit v 8.0 file into Archicad v10.0
notagain
notagain Avatar
4 Stars: 1 Votes
in the future you might want to check you IFC out put with an IFC reader....
http://www.nemetschek.co.uk/ifc
you shouldn't have had any problems going back and forth with the IFC format...curious why it didn't work
I really want this to work...some good things some bad
Tue, Mar 24, 2009 at 4:21:51 PM | Converting a Revit v 8.0 file into Archicad v10.0
BVHdarin
I am not saying it doesn't work I was just wondering how well it works.  I guess I was looking for suggestions from users who have experience going back and forth between the two programs.
Converting ArchiCAD objects into Revit families
Thu, Jan 17, 2013 at 9:43:29 AM
importing from archicad
Thu, Nov 27, 2008 at 10:55:38 PM
Revit vs. Archicad [ 1 2 ]
Fri, Sep 28, 2007 at 11:57:54 PM
15
Architect is using ArchiCAD Structural Consultant using Revit?
Thu, Nov 27, 2008 at 11:23:30 PM
REVIT 2009 VS ARCHICAD 12 [ 1 2 3 ]
Wed, Aug 22, 2012 at 10:03:49 PM
33
Page generation time: 2.2192
