47 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Phasing and grouping?
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Why is it that when I asign a phase and then group and place that same group all the instances lose the phase that I have assigned them? Also when I select all instances of some objects I am unable to change the phase of that object overall. Any solutions?
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
because the grouped object or copied object will revert back to the phase of your view.... when picking all instances of one object you should be able to change phasing globaly, maybe some objects are locked or on another workset (?) if so, take control of all the worksets and than try to change... HTH
grouping and phasing- is there a better way? |
Wed, Nov 6, 2019 at 2:58:09 AM
Phasing - Building Already Done but Dind't Set up Phasing |
Tue, Dec 15, 2009 at 7:40:42 AM
Grouping Floors |
Mon, Aug 22, 2005 at 3:47:49 PM
Graphical Column Schedule - Not Grouping all similar instances |
Wed, Nov 5, 2008 at 11:11:18 AM
phasing |
Tue, Oct 23, 2012 at 8:20:21 AM
Members: | 2022368 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
