42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Fill Pattern- Dry Stack Stone
Tue, Dec 5, 2006 at 4:08:17 PM | Fill Pattern- Dry Stack Stone
jrusso
4 Stars: 2 Votes
Looking for dry stack stone similar to something you would see on a Frank Lyod Wright house.
Any one? The fill patterns I found were not able to be load as model patterns. Southern Ledge stone being one of the fill patterns.
Tue, Dec 5, 2006 at 5:29:50 PM | Fill Pattern- Dry Stack Stone
framerman
4 Stars: 13 Votes
hopefully I get this one right. I'm going by memory which can be bad! lol. If you are talking about hatch patterns in model, they are very easy to change. You have to open up the hatch pattern and edit the model/drafting part. If it's not already in there, then you have to make it this way.
You can find out much more information easier than I can give it by looking in the default hatch pattern that comes with revit and you can locate that bad boy at......
 C:\Program Files\Autodesk Revit Building 9.1\Data\revit.pat
Surface pattern
Mon, Sep 10, 2007 at 11:18:02 AM
Stack Stone Hatch
Fri, Nov 16, 2012 at 7:38:58 PM
Fill Pattern
Mon, Jun 5, 2006 at 8:13:22 PM
fill patterns and stone walls
Fri, Aug 18, 2006 at 8:54:33 AM
Fill pattern not showing up in print
Tue, May 1, 2012 at 11:20:15 AM
Page generation time: 1.2371
