61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Model Cut Pattern?
Thu, Nov 11, 2004 at 4:35:40 PM | Model Cut Pattern?
Redrose
Hi, Is it possible to use a Model pattern in the cut view? I'd like to be able to count the number of bricks up to a window when I'm looking at a section view. If I could assign a Model-mode brick pattern this would do it, but the Model option is greyed (grayed) out for cut patterns. Is there a way? Thanks.
Wed, Jan 30, 2013 at 12:16:11 AM | Model Cut Pattern?
develocon
develocon Avatar
Sorry there is no way to do this, however you can quicly and easily do what you want with a repeating detail componant.
there is even a brick detail componant in the metric library already.
just creat a new repeating detail using a brick and mortar at a fixed spacing and you can add these to your secions in no time.
I also find it useful to align and lock the detail to the model so if the wall moves the detail does also.
cut pattern issue
Wed, Jan 28, 2015 at 3:53:15 PM
loss of cut pattern
Fri, Nov 28, 2014 at 8:47:10 AM
Revit 2015 Solid Cut Fill Pattern
Thu, Sep 22, 2016 at 8:27:54 AM
Rendering...weird cut pattern?
Tue, Aug 11, 2009 at 2:30:12 AM
Stiar cut pattern or fill pattern.
Sun, Feb 19, 2006 at 11:46:36 PM
Page generation time: 1.9266
