40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rendering platforms
Thu, Nov 30, 2006 at 11:20:46 AM | Rendering platforms
daudesign2
I need some assistance deciding what is the best rendering platform to use post Revit and Accurender. I have researched VIZ 2007, 3ds Max 9, Renderzone, Piranesi, Photoshop CS 2, and Cinema 4d. I wish to improve the quality of photorealism in my renderings, and I need some input. Any ideas and input would greatly help.
Thanks!!!!!
Thu, Nov 30, 2006 at 12:11:54 PM | Rendering platforms
framerman
4 Stars: 13 Votes
Viz and Max are the same program essentially, both owned by Autodesk, which I believe is your best alternative. Also, don't cut accurender short. Revit has just a stripped down version, check out their full version.
Photoshop is 2d...apples and oranges here
Fri, Dec 1, 2006 at 2:26:27 AM | Rendering platforms
lukaszsw
lukaszsw Avatar
3 Stars: 4 Votes
It's quicker to make a render in revit then to assign materials again in 3ds max. Unless there is a way to export materials to 3ds max than I'll try full accurender.
Fri, Dec 1, 2006 at 6:36:27 AM | Rendering platforms
framerman
4 Stars: 13 Votes
you can export all your materials to max/viz.
Thu, Feb 21, 2008 at 2:06:41 AM | Rendering platforms
sidman
I am new to 3ds max. I imported building model from revit to 3ds max. I placed some trees in revit which I cannot see in 3ds max when I render the scene. Also I am not able to add sky. Please help me.
Can anyone suggest me a tutorial from where I can view details for rendering in 3ds max.
Railing following path of stairs with platforms
Wed, Oct 14, 2015 at 5:30:18 AM
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:38 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:40 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:52 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:51 PM
Page generation time: 2.0624
