80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Flat Oval High Pressure Duct???
Wed, Nov 29, 2006 at 11:27:54 AM | Flat Oval High Pressure Duct???
jonpaulking
Has anyone using systems had to draw high pressure flat oval duct or will it be part of the next version of systems. Oval is pretty much what we use on all of our projects and so far I have not seen any way to draw it. thanks
Thu, Dec 11, 2008 at 3:09:00 PM | Flat Oval High Pressure Duct???
Wneuok
Looks like this is still an issue with Revit MEP 2009, hasn't anyone worked on a building where they had existing oval ductwork? How would you deal with a project like this?
Fri, Oct 16, 2009 at 3:24:10 PM | Flat Oval High Pressure Duct???
JillBernhardt
5 Stars: 3 Votes
Hello, I have customers that are using rectangular duct to mimic the size of flat oval duct so that it is detected when doing interference detection.  They have created a custom duct size label that appears that displays the size the way they would display the size of an oval duct, if they had them.  This is an issue in Revit MEP 2010 as well.
Jill Bernhardt
    Blog:  The BIM Bulletin
Fri, Oct 16, 2009 at 5:04:14 PM | Flat Oval High Pressure Duct???
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
riddle me Jill. What is the point of the oval duct is to fit more into a small space? how is a rectangle going to help to take up space? Not to mention that they would be unable to return accurate duct flows since the dynamics are different.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Fri, Oct 16, 2009 at 5:13:45 PM | Flat Oval High Pressure Duct???
JillBernhardt
5 Stars: 3 Votes
Not a perfect fit, that I will certainly agree!  But, it gives them roughly the space allocation they need for their oval ducts when doing interference detection which is what they were most concerned about.  How do you represent oval ducts in Revit, Eddie?
Jill Bernhardt
Fri, Oct 16, 2009 at 5:56:12 PM | Flat Oval High Pressure Duct???
Eddieboarder91
4 Stars: 8 Votes
I have created an api tool that works nicely, they I have added the calculations into schedules so that I can calc the flow and pressure drop.
Sat, Oct 17, 2009 at 7:49:00 AM | Flat Oval High Pressure Duct???
JillBernhardt
5 Stars: 3 Votes
Sounds great.  I'm glad it works for you.
Jill Bernhardt
duct static pressure loss
Mon, Aug 15, 2011 at 2:18:12 PM
How to get an oval duct in a model that doesnt have it in 2012
Sun, Sep 4, 2011 at 7:43:26 AM
oval to round tee fitting family
Thu, Jan 13, 2011 at 4:25:42 PM
Duct won't tap to oval duct.
Tue, Aug 22, 2017 at 12:38:50 AM
Duct pressure loss calculation
Tue, Sep 29, 2015 at 3:32:06 AM
Page generation time: 0.2913
