Forums >> Revit Building >> Technical Support >> Autocad model importing.
Wed, Nov 29, 2006 at 5:48:42 AM | Autocad model importing.
johann
When downloading all the fancy autocad models like cars, chairs etc and importing these into Revit I find that the PC slows down considerably without enlarging the file all that much.
When rendering these imported models in Revit the colours tend to be monochrome and un-editable.
Is there a way to import these models, have the PC operate at an acceptable speed and change the render materials at will?
Thanks.
Wed, Nov 29, 2006 at 8:44:38 AM | Autocad model importing.
framerman
4 Stars: 13 Votes
I believe you must have your models set to bylayer and bycolor to easily change the materials. The materials you should be able to change in the object styles of the settings menu under the imported tab.
The slowness I would think would be attributed to the amount of polygons in the model adding to the file. I don't think Revit is really made for importing high poly count models or even really medium poly counts. I have taken a model from Revit into Max and you can easily rotate the model around without any slowdown.
Importing Autocad background - Revit Model to exceede 2 miles across [ 1 2 ]
Sat, Apr 17, 2010 at 7:29:52 PM
20
Importing a 3d autoCAD model - preserve individual 3d elements in model
Wed, Apr 21, 2010 at 1:29:11 PM
importing from AutoCAD
Thu, Jul 19, 2007 at 1:47:15 PM
importing Autocad files - modelspace & paperspace!
Tue, Jul 17, 2007 at 8:25:49 AM
Linking AutoCAD Site Contour missing 2014
Wed, May 27, 2015 at 7:56:32 AM
Page generation time: 1.4621
