Forums >> Revit Building >> Technical Support >> hatch pattern
58 Posts No Rating |
hi, is there a way we can change the line weight and line type of a hatch pattern?
you can change only the line weight and type of the lines that delimit the hatch. -paolo
27 Posts No Rating |
what does that mean?
When you create an hatch you define its perimeter: only the perimeter lines are editable in line weight and in type. you're welcome. -paolo
sorry, i didn't mean to be rude. can you change the lineweights of the existing hatches Also how do you go about creating new hatches? thanks for your help
Edit the fill patern and pick the lines, in the upper left corner are the different line types, change to the line type you want. Invissable lines will not show the border if you need to hide an object without the border showing.
To make new hatches there is a program called Hatchkit or you can edit an existing pat. file of an existing hatch.
Macca Sunshine Coast QLD Australia |
If you want to edit your hatches, you have to know what symbols and numbers you will find inside stand for. For those who don't, there's an explanation inside the file revit.pat that is usually located in c:/Documents and settings/all users/application data/Autodesk/revit building x/training/metric and family templates/ There are 2 types of hatches: DRAFTING and MODEL, the first take the scale of the view, the last take the scale in the real world unit you specified in the .pat file. The correct form for a single line hatch -drafting ;%UNITS=MM *name,description ;%TYPE=DRAFTING angle of rotation of the origin axis took from the x-axis CCW, x coordinate of the origin, y coordinate of the origin, shifting from the origin of the next line, offset from the origin of the next line, first solid line [, if negative stands for the first space, if 0 stands for a minimum lenght line such as a point, etc...] -model ;%UNITS=MM *name,description ;%TYPE=MODEL angle of rotation of the origin axis took from the x-axis CCW, x coordinate of the origin, y coordinate of the origin, shifting from the origin of the next line, offset from the origin of the next line, first solid line [, if negative stands for the first space, if 0 stands for a minimum lenght line such as a point, etc...] it's a valid hatch also for Autocad user because the extra parameters %UNITS and %TYPE are preceeded by a ";" that makes them a comment for Autocad. You have to know that you can do a unique file with all your hatches of different types and load it every time you need it, without spending much time in selecting from a list of multiple .pat files. hope this would be useful. -paolo
1 Posts No Rating |
Hi I have a cosultants cad drawing which i am linking into my revit Drawing, and it contains hatches and linetypes containing text. How can i get these to show up when linked in the Revit view. the hatches show up, but are all over the place...what can i do? LIVE
19 Posts No Rating |
Revit does not support text in line types or text in hatch patterns, unless the text is drawn line by line into the hatch. Also, u can define new hatch patterns by going to settings > fill patterns > new > custom > and import a .pat file.
Exporting hatch pattern |
Thu, Sep 18, 2014 at 6:27:36 PM
hatch pattern not printing |
Mon, May 8, 2017 at 12:56:52 PM
Hatch pattern |
Tue, Jan 13, 2009 at 10:23:48 AM
Hatch 22- Curve Pattern |
Wed, May 30, 2018 at 4:07:08 PM
custom hatch pattern without hatch editor |
Wed, Jan 28, 2015 at 8:46:59 PM
Members: | 2102383 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
