135 Users Online (133 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> alternate dimensions
Tue, Nov 28, 2006 at 3:57:22 PM | alternate dimensions
ANormand
Does anybody know how to get a dimension line to show alternate dimesions (imperial and metric)? ie. 10'-0" (3048mm)
Tue, Nov 28, 2006 at 5:24:51 PM | alternate dimensions
framerman
4 Stars: 13 Votes
I think if worse comes to worse, you can either manually type it in (not a good answer) or select the dimension and enter a formula in the suffix section converting the inches to mm's in parenthesis (another not good idea, very manual) I don't know if there's a way to have this done by type or not. Wish I had better information for you.
Tue, Nov 28, 2006 at 5:39:23 PM | alternate dimensions
TomDorner
4.5 Stars: 25 Votes
It is not something that Revit can do.  The best I can come up with is to place two dimensions on top of each other, one using the project units [say imperial] and then another defined as metric that does not use the project units but over-rides them to metric.  You have to move the text of one or both dimensions from on top of one another and add the prefix/suffix of your choice.
The other option is to have the two dimension styles and create two views one metric and another imperial.  Dimension one view then copy/paste the dimensions to the other view and change them to the other dimension style.  You can then place each view onto a sheet on top of each other or seperately.  If on top of each other then yu would have to move the dimesnion text in one of the views.
Edited on: Tue, Nov 28, 2006 at 5:46:07 PM
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, May 24, 2010 at 1:21:05 PM | alternate dimensions
structuresguy
Sorry to dig up an old thread, but has a solution to this glaring omission ever been implemented by Revit?  I have a project now that requires us to show imperial and metric dimensions, and their example shows it thusly:  10'-0" (3.048m).  So I don't think they will like it to have two dimension strings for each dimension.  Not to mention how messy the plans will get.  I have RS2011 and can't seem to find any way to do this.
Mon, May 24, 2010 at 1:25:29 PM | alternate dimensions
TomDorner
4.5 Stars: 25 Votes
Sorry, almost four years later the answer is still the same.  Revit cannot do alternate dimensions like AutoCAD.  The only other option now I can add is export to ACAD for dimensioned plans now that the CAD exports from Revit preserve dimensions.  In earlier days they cam out as lines, tick and text.
Tom
Mon, May 24, 2010 at 1:30:15 PM | alternate dimensions
Unless someone builds an add on to do this, your optios are:
  1. Use two strings
  2. Use text for one of the trailing dimension.
Now for the out of the box answer..... Use two strings with them both in the same place and spread the text apart....
Darn ... Tom beat me to it....and I see the out of the box he already had too.
Edited on: Mon, May 24, 2010 at 1:32:02 PM
dimensions with alternate units
Tue, Feb 27, 2007 at 6:13:09 PM
Alternate Dimensions
Wed, Dec 5, 2007 at 12:28:20 PM
Using Revit for multi-level alternate
Tue, Apr 29, 2014 at 11:16:33 AM
Alternate Wall system - 2008
Tue, Oct 9, 2007 at 8:50:44 PM
Alternate floor plan?
Tue, Aug 21, 2007 at 3:11:29 PM
Page generation time: 0.6060
