48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Flat Roof
Tue, Nov 28, 2006 at 2:20:47 PM | Flat Roof
Hazem
Hi
I have here 4 walls having different hights in its profile
I want to cover this constructrion with a roof which its 4 points are the top level of these walls
Tue, Nov 28, 2006 at 4:05:18 PM | Flat Roof
puzzle
4 Stars: 10 Votes
I would create a in place roof. Go to Modelling<Create<Roof give it a name then chose Solid extrusion<Solid Blend. Go to one of your elevations (short side) then draw your front & back. It will show as edit top & edit bottom. When you have finished sketch, go to site plan & you can adjust the length of the roof.
Macca
Sunshine Coast
QLD Australia
Sun, Dec 3, 2006 at 1:05:42 PM | Flat Roof
Hazem
Well thank you very much
I did that and it worked but Can You Do it using NURBS?
I tried alot but it never works
Sun, Dec 3, 2006 at 2:04:30 PM | Flat Roof
Scott Davis
3.5 Stars: 3 Votes
Create a Mass, using a Solid Blend.  You will switch the workplane to the surface of one of the end walls.  The bottom profile will be the shape of the wall.  The top profile will be the shape of the opposite wall.
Then place roof using Roof by Face. It's very simple to do.  You can even use dimensions on the sketch of the profiles to set the elevations of the 4 points on the corners.
Tue, Dec 5, 2006 at 1:48:27 PM | Flat Roof
Hazem
Ok guys thank you
BUT I mean if I had 4 walls like those in the picture and i want to make something like "Edge Surface" in Autocad for a roof for these walls
How can i do that ?
may be by using NURBS but i don't know how .
can any body tell me?
Tue, Dec 5, 2006 at 3:51:57 PM | Flat Roof
Scott Davis
3.5 Stars: 3 Votes
There are no NURBS in Revit.  Use a Mass, make it a solid blend with different profiles on each end, and Revit will connect the ponts for you.  Then use Roof by Face on the Mass.
Thu, Dec 7, 2006 at 1:45:27 PM | Flat Roof
Hazem
NO NURBS?
Check the HELP and you will find that you can import NURBS and convert it to roofs
But it always fails
Thu, Dec 7, 2006 at 2:07:02 PM | Flat Roof
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this link. it may help with the importing of NURBS
http://www.wikihow.com/Create-a-Freeform-Roof-in-Revit
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Dec 7, 2006 at 3:22:32 PM | Flat Roof
Scott Davis
3.5 Stars: 3 Votes
Correct.  There are no NURBS natively in Revit.  You can import NURBS based objects from other programs, and it doesnt always fail.  Here is a roof created from a Rhino file, saved as an SAT, and then imported into a Revit mass Family.  The family was loaded into Revit, and then Roof by Face was used.
Flat roof Overhang with profile
Tue, Apr 13, 2010 at 9:59:56 AM
Flat roof with crickets
Mon, Jun 9, 2008 at 3:50:45 PM
Sloped flat roof
Mon, Jun 18, 2007 at 2:24:41 PM
Flat roof
Fri, Mar 20, 2020 at 4:58:56 PM
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Page generation time: 0.6235
