84 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> Using mass in more than one project
![castle Avatar](user_avatar/20463.jpg)
![4 Stars: 6 Votes](/images/stars_4.gif) |
I created a mass in a recent project that I would like to be able to use in a current project. Is there any way I can do this, without creating the mass again, and every time I want to use it? When I created the mass, I only saved it in that project. I looked in previous forum posts, but didn't see anything about this. Thanks in advance : -)
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
You can copy and paste the mass from one project to another. Be sure that mass visability is on in the project you are pasting into to see the mass. If you have the need for the same mass over and over, then it might be best to create a stand alone massing family from the mass.rft family template. HTH
Tom www.reviteer.com http://twitter.com/Reviteer |
Thank you, Tom ..... I had not used the copy to clipboard/paste command before .... it will save a lot of time on future projects. Of course, when I first tried to use it, it wouldn't paste into the new project, so I looked on previous posts and found that I had to have both projects open at the same time. Then, of course, it worked ... duh! So, thanks again : -)
Conceptual Mass Project Space Visibility |
Fri, Jul 15, 2011 at 1:46:11 PM
Unable to load conceptual mass into project |
Fri, Sep 11, 2015 at 1:40:26 PM
Sharing Coordinates Conceptual Mass Environment and Project Environment |
Sat, Nov 16, 2013 at 10:14:00 AM
I need help for Mass from other Application |
Fri, Jun 21, 2013 at 7:32:51 AM
Conceptual Mass Subcategories |
Wed, Jan 2, 2013 at 12:01:36 PM
Members: | 2017238 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
