Forums >> Revit Building >> Technical Support >> Title block printing grey when using "selected views"
15 Posts No Rating |
When I print all my sheets using "selected views" random pages have their title blocks greyed out similiar as if I had printed a single sheet with the view active. Any sugestions on why this is happening?
I have the same problem - annoying isn't it? Sorry - don't know why it happens either, would like to know the answer.
Deb |
5 Posts No Rating |
Check if the view is activated in your viewport.
19 Posts No Rating |
Yeah, the only reason that has ever happened with me is when viewports are activated.
It happens even when the viewports aren't activated!
Deb |
What I think is happening is: if I activate a view and then change to a different view without deactivating the first view, then even though the first view defaults back to deactivated, when I print by "selected views" it will print grey. So what I do now, is before I do a batch print I close and re-open the file ensuring that all views are correctly deactivated. This is definately a pain with bigger files, but it's still a lot faster than printing each page separately.
Trouble printing to Oce 30"x42" |
Thu, Sep 11, 2008 at 3:51:20 PM
Title Block link from Schedule? |
Thu, Sep 13, 2007 at 4:12:01 AM
Printing without title block and to 1"=100' |
Thu, Dec 8, 2005 at 4:58:40 PM
Going from "Title w line" to "Plan Title" |
Thu, Aug 23, 2007 at 11:53:12 AM
Title Block Labels |
Wed, Feb 14, 2007 at 11:52:50 AM
Members: | 2102303 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
