65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Showing break lines with Ramps and Stairs
Mon, Nov 27, 2006 at 3:03:10 PM | Showing break lines with Ramps and Stairs
azarch
I can't figure out how to get the standard Ramps to show a break line when they pass through the cut plane.  The stairs do this automatically and you can control the break line's visibility through the properties dialog box.  Anyone know how do make a break line appear for Ramps?
Fri, Feb 9, 2007 at 8:48:05 AM | Showing break lines with Ramps and Stairs
arkitektmsh
3 Stars: 1 Votes
This is a good question and one that i have had.  Anyone out there have an answer to this one?
Fri, Feb 9, 2007 at 9:37:09 AM | Showing break lines with Ramps and Stairs
Why not just add a detail component - break line from the drafting menu?
Fri, Jun 3, 2011 at 10:54:13 AM | Showing break lines with Ramps and Stairs
stealthnyc
4.5 Stars: 2 Votes
Its 4 years later and the program still can't automatically generate a break line.  Hmm..
Tue, Dec 6, 2011 at 4:15:20 AM | Showing break lines with Ramps and Stairs
FrankyDHalliday
FrankyDHalliday Avatar
3 Stars: 2 Votes
Whay are you using ramps, you can't spot level them.
Dr. Zaius: Ah, yes - the young ape with a shovel. I hear you're planning another archeological expedition. Cornelius, a friendly word of warning - as you dig for artifacts, be sure you don't bury your reputation.
Mon, Jul 30, 2018 at 7:45:39 AM | Showing break lines with Ramps and Stairs
jayantanth
In 2018 still this is not implementaed.
Mon, Jul 30, 2018 at 11:02:36 AM | Showing break lines with Ramps and Stairs
sllana
5 Stars: 2 Votes
What I do, is to make a detail group made of a masking region, rectangular and invisible lines except for one side in which I draw the break line (this one visible of course). P.D. 4 years? 18!!
View Breaks and break lines
Tue, Jun 26, 2012 at 6:49:55 PM
TYPE SELECTOR for ramps and stairs
Thu, May 3, 2007 at 2:46:53 AM
Detail/ Break lines
Mon, Apr 29, 2013 at 4:02:35 PM
Break lines sizes.
Mon, Mar 2, 2009 at 2:15:32 PM
Hidden lines on stairs going down
Wed, Jul 25, 2007 at 1:26:42 PM
Page generation time: 1.5952
