69 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> Rendering
3 Posts No Rating |
I'd like to use an external rendering engine in conjuction withh revit for better renderings, can anyone advise me on which one is most compatible and how to link up the two.
as far as i know you cannot directly link revit models into a external renderor. you have to export out as a dwg or other to utilize a different renerdering engine such as max, viz, etc. HTH
Edited on: Mon, Nov 27, 2006 at 8:35:21 AM
3 Posts No Rating |
thanks, so which software do you suggest i use after exporting to dwg, and will the materials still be recognised by the other software?
i don't do a lot of rendering other than with Revit. most people use max or viz. but i'm sure there are others. i think if you are more interested in haveing materials export and carry over, you should check the polymesh option when exporting. hopefully someone else can shed more light on this subject for you? HTH
Edited on: Tue, Nov 28, 2006 at 5:42:18 AM
I use Maya 7.0 and below as these versions import DWG fine, then you just texture away and create your own scene using your own lights etc. revit rendering is bad, Max,Maya & Viz are the best for rendering. if you wish to keep your own revit textures applied to your model than Viz would be the way to go. hope this helps Josh
----------------------------------- J-Ro |
Realistic Rendering [ 1 2 ] |
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ] |
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue |
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009 |
Mon, May 11, 2009 at 4:32:50 PM
help with rendering! |
Wed, Aug 10, 2016 at 10:47:17 PM
Members: | 2030522 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
