72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Can we create our own ceiling grid?
Mon, Nov 8, 2004 at 9:04:34 PM | Can we create our own ceiling grid?
samlam
I want to have a see-through ceiling grid that allows me view objects above the false ceiling.
Mon, Nov 8, 2004 at 9:07:39 PM | RE: Can we create our own ceiling grid?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Locate you ceiling grid material in your material settins and set the transparency to 100... You should now be able to see through the ceiling, also if it doesn't already have an appropriate grid you can set this in your surface pattern.
Mon, Nov 8, 2004 at 10:49:22 PM | RE: Can we create our own ceiling grid?
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I think there should be a ceiling grid tool like we have for curtain grids...
Hiroshi Jacobs
The Catholic University of America
Thu, Nov 11, 2004 at 3:16:34 AM | RE: Can we create our own ceiling grid?
samlam
Thank you Mr Spot. I have created wood strips over the transparent ceiling. Revit should have features to allow create more exotic ceilings.
Thu, Nov 11, 2004 at 4:18:48 PM | RE: Can we create our own ceiling grid?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can create extremely detailed ceilings using in-place ceiling families. I've create a detailed timber batten ceiling with battens at various angles to each other and overlaying each other...
Thu, Nov 18, 2004 at 8:38:06 AM | RE: Can we create our own ceiling grid?
samlam
I can make the ceiling transparent in shading view only. It appears grey when in rendering view. Is there a way to overcome?
Thu, Nov 18, 2004 at 5:25:47 PM | RE: Can we create our own ceiling grid?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes you have to create a trasparent accurender material with the finish you require. Locating your material in the material settings, under the accurender material press the open button. Now you can change your material. If you would like to edit your own you can choose one and select edit... Then give the appropriate trasparency setting etc etc. Just remember after creating the material check the material settings trasparency that you changed original as it may have updated with the accurender material. Let me know if you need a better break down.
Mon, Jul 11, 2011 at 8:35:02 AM | Mr Spot
EMJacobsen
Quoting Mr Spot from 2004-11-11 16:18:47
"You can create extremely detailed ceilings using in-place ceiling families. I've create a detailed timber batten ceiling with battens at various angles to each other and overlaying each other..."
So, what is the best way to go about this?
Can you create your own Ceiling Grids??
Thu, Jan 5, 2017 at 8:44:32 AM
Light fittings in ceiling grid
Tue, Feb 8, 2005 at 6:33:50 PM
Ceiling Grid
Wed, Mar 16, 2011 at 3:15:51 PM
Ceiling Grids in Revit 2011
Fri, Jul 22, 2011 at 8:35:25 AM
rendering ceiling grid
Wed, May 16, 2007 at 1:37:32 PM
Page generation time: 0.8128
