111 Users Online (110 Members):
Forums >> General Discussion >> Revit Project Management >> Converting 3D objects from ADT to Revit families? Any suggestions?
![Hogmodo Avatar](user_avatar/1029.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
There is a lot of 3D products being produced in ADT that I would like to import into Revit for rendering purposes. Is there an easy way to do this importing?
![3 Stars: 2 Votes](/images/stars_3.gif) |
I found that the best way to do that was to create a new family for each object. So import the object into the family then load that family into the project. This way you can also add all the parameters to the object that you want.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
You can take a 3D DWG and insert it into a family. Many of the OTB (out of the box) Revit families are nothing more than ADT 3D DWG files. Material assingments within Revit are then handled by layer for the DWG objects Settings>Object Styles>Imported Objects>Material HTH
Tom www.reviteer.com http://twitter.com/Reviteer |
Converting ArchiCAD objects into Revit families |
Thu, Jan 17, 2013 at 9:43:29 AM
New to Revit, converting from CAD questions |
Thu, Apr 28, 2011 at 10:22:40 PM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects |
Fri, Oct 12, 2012 at 7:31:58 AM
REVIT X ADT |
Sun, Jan 8, 2006 at 10:40:42 PM
Converting Room Areas to Walls and Importing ADT lines into Walls |
Mon, Sep 15, 2008 at 12:44:51 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
