49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Irregular (on plan) shaped walls
Is it possible to create a "freeform" (in plan) wall? I am trying to model an historic building which has very irregular walls. What I would ideally like to do is to draw the plan of the walls and then extrude it to the correct height. The only work around I can come up with is to create these irregular sections of the wall with an "Extrusion" Mass Object. But it then obviously does not behave as a wall (ie cannot host doors / windows / does not join with adjacent walls / does not bound rooms / etc) Is it possible to do what I am after and have the object behave as a proper wall? Man thanks, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
Try doing an "in-place" family by going to the Modeling tab>Create> choose "Walls" as your category then use an extrusion as you described. HTH
When I've tried this, the wall does not behave as a wall ... doesn't host objects.
Many thanks for the advice- worked a treat. And it hosts doors, windows, etc. Regards, Ian
Irregular Shaped Callout |
Thu, Sep 9, 2010 at 3:19:12 PM
Thu, Oct 4, 2007 at 1:51:11 PM
customerized curtain panel doesn't work with the irreglar shaped panel? |
Sat, Jul 10, 2010 at 1:48:42 PM
Irregular Ceiling |
Mon, Aug 4, 2008 at 1:45:52 AM
Curving a Truss around an irregular mass |
Sun, Mar 1, 2009 at 8:19:44 AM
Members: | 2042257 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
