Forums >> Revit Building >> Technical Support >> Imported Raster Images Not Printin
4 Posts No Rating |
Raster images (jpegs) that I've inserted will not print no matter what I do to adjust settings in the Print Set Up box. I've already verified that the files show up in the raster images list. Has anyone experienced this? (F.Y.I the images are part of a titleblock family that is loaded into the project). Thanks!
11 Posts No Rating |
hey there i have the same problem, iv placed a sky image in my elevation and it wont let me print to PDF dont know y
32 Posts No Rating |
use default sky, then take camera view and align it to elevation then render it... or else export renderd image as png or jpeg to photo shop png is good u dont hav to edit...white space.. then put the sky.. http://www.revittut.blogspot.com/
U can also use decal option it that u ll get picture in 3d but u can see only when rendered http://www.revittut.blogspot.com/
thanks, but im printing to a PDF every time i export the PDF to photoshop i lose the image quality, i need to have a title box on the page, is there any other way thanks, kunal
4 Posts No Rating |
I had the same problem and i had to import the raster image into the sheet space and not the view drawing. I think the problem was wen I imported it I had to rotate the image so i did the rotating and sizing in another program before importing it. see if this helps.
8 Posts No Rating |
I have the same damm problem. Raster image is on the sheet. I can't even get to show up in print preview, sometimes I get a partial image a ka a coner of the entire image. Auto desk for you They screwed auto cad up relase after release, it will be the same for Revit too bad because I loved 2009. I am going to try export to dwf or dwg to print. something ought to work. I thought they would fix this in the service pack NO LUCK
13 Posts No Rating |
any luck with this yet revking, I'm having the same problem you described. (using structure 2010) worked fine in 2009 but project got upgraded to 2010 by architect and now..... "Raster image is on the sheet, I can't even get to show up in print preview." thanks
Read some of the similar linked threads shown below. They may contain your answer.
FYI - Found out we needed to switch a setting in our (KIP) plotter preferences. switched from KIP GL to KIP Script http://forums.augi.com/showthread.php?t=106939&page=2
