46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Chief architect to revit..?? Need help.
Sat, Nov 18, 2006 at 11:27:28 AM | Chief architect to revit..?? Need help.
jarmy
Anyone use chief architect ??
How can i import 3d model from chief architect to Revit v9 ??
I exported in dwg(or dxf)format from chief, then tried import in revit. but revit can't read it.
Need help..How can i import to revit from chief architect safely..??
Edited on: Sat, Nov 18, 2006 at 11:49:00 AM
Sun, Nov 19, 2006 at 9:28:20 PM | Chief architect to revit..?? Need help.
eldados
eldados Avatar
4.5 Stars: 8 Votes
Hey Jarmy,
what you did was the right way... export to 3D DWG and import into Revit.
THOUGH, you won't be able to explode it and retain any information, you might be able to import it into a Mass family and than import the Mass family into your project, you might be able to pick walls and roof by face, (not sure how it will work for you)
bottom line, you might need to draw from scratch, because the information won't be very useful for Revit...
Integrator
KarelCAD
Mon, Nov 20, 2006 at 2:56:15 AM | Chief architect to revit..?? Need help.
jarmy
Thank for your reply.
it's right..can't explode it.
I will seach othe way.
Thank you.
Tue, Nov 21, 2006 at 8:07:15 AM | Chief architect to revit..?? Need help.
thundercad
eldados:your answer is very informing. I found using mass or imported object into mass family is a very useful way to reinforce the native revit modeling. I tried to use mass (some are imported) in family editor to create more custom made baluster, roof, window, etc. However when I drag the loaded mass into family object, I got such message: "None of the created elements are visible in 3D View: View 1 View. You may want to check the active view, its Parameters, and Visibility settings." (please see attached screen catch). If I save this family type and load into project and use it, the mass I put in in family editor is there and become vesible in project (see the second scrren catch image) I believe it must has something to do with visibility/graphics settings in family editor (templete), but cant figure it out. Can you please shed some light on this one, thanks in advance.
Tue, Nov 21, 2006 at 4:23:13 PM | Chief architect to revit..?? Need help.
eldados
eldados Avatar
4.5 Stars: 8 Votes
yeah mate,
you see up there next to your 3D button, there is a button that looks like a cube? that's turning show/hide mass...
Integrator
KarelCAD
Tue, Nov 21, 2006 at 10:02:42 PM | Chief architect to revit..?? Need help.
thundercad
Thanks for the swift reply Eldados! The thing still trouble me now is the mass turn on/off button always turning gray in family editor. In project file it works fine. anyway to turn show mass on inside family editor (templete), thanks again.
Revit vs. Chief Architect
Thu, Jul 1, 2004 at 3:15:42 PM
Which version to choose
Tue, Jun 5, 2018 at 10:14:16 AM
importing / exporting
Thu, Mar 30, 2006 at 7:56:04 PM
Revit Machines by ThatCADGuy.com
Tue, Aug 9, 2011 at 5:13:08 PM
Just want to introduce myself.
Wed, Jan 16, 2008 at 12:57:19 PM
Page generation time: 2.3927
