99 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> room tag families?
8 Posts No Rating |
Hi. This is probably simple but I have searched and searched on these forums and haven't quite found the answer. I am trying to insert rooms into my project (revit 9) and when I click the 'room' button it says I need to load a room tag family into my project. Where can I get a default family from? Thank you
![4 Stars: 13 Votes](/images/stars_4.gif) |
Your room tag should be in your annotation folder. Hit File>Load from Library>Load Family and navigate to your annotations folder under c:\doc and sett\all users\application data\autodesk\Revit\Library I'm surprised it's not already there. It should be there in your default template that opens up when you start Revit.
8 Posts No Rating |
I'm using the program at my university, it might have been installed somewhere else. If I can't find the folder, is there a way to download some tags somewhere?
It should be right where I said. But if not... http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7177665
8 Posts No Rating |
Maybe the problem is that I don't really know what I am looking for as far as a room family goes. I've found a lot of other family types on the system like walls and doors, but nothing about rooms... Maybe I will seek out a tech or someone. Thank you
8 Posts No Rating |
Nevermind I found the room tag family, thanks a bunch!
8 Posts No Rating |
On this same topic, is there any way to align and cenetr these tags within the rooms?
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
Room Tag Leaders |
Thu, Oct 21, 2021 at 9:45:56 AM
ROOM TAG TAGS ONLY HALF OF THE ROOM |
Wed, May 6, 2015 at 8:58:21 AM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
