120 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Beam family options
Thu, Nov 16, 2006 at 12:20:35 PM | Beam family options
wataeli
5 Stars: 3 Votes
I understand beams need either a column or bearing wall. I created a suspended ceiling grid using the beam family template. Can I change the properties of the "beam" I created so it can connect to a non-bearing wall? My reasoning is that the grid will be supported by hanger wires, not a bearing wall. So I don't want to label my walls bearing if they really don't need to be. Or, is there another family template better suited for what I need? The only tutorial I found for family templates was the one that shows how to create a truss family using the structural beam template. I'd appreciate any tips or advice. Thanks! - Elisa
2D detail item nested to Steel Beam family - Placing level problem
Fri, Jan 13, 2012 at 12:00:36 AM
Creating a beam family
Sun, Apr 17, 2011 at 9:06:01 PM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:37 PM
beam revit family
Fri, Sep 10, 2010 at 12:33:43 PM
Castellated Beams
Tue, Jan 22, 2013 at 4:43:21 AM
Page generation time: 2.2581
